View the IPv6 address bindings that IP Source Guard (IPSG) allows.
View the IPv6 address bindings for port 1/3.
Switch:1>show ipv6 source-guard binding interface gigabitEthernet 1/3 Slot/Port IPv6 Address ========================================================== 1/3 2001::10:10:0:1 1/3 fe80::210:94ff:fe00:550b -----------------------------------------------------------
View the IPv6 address bindings for a specific IPv6 address.
Switch:1>show ipv6 source-guard binding fe80::210:94ff:fe00:550b Slot/Port IPv6 Address ========================================================== 1/3 fe80::210:94ff:fe00:550b -----------------------------------------------------------
The following table defines parameters for the show ipv6 source-guard binding command.
Variable |
Value |
WORD<0-46> |
Identifies the IPv6 address. |
interface gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
